7 members (Peggy M, mick53, Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51), 130 guests, and 2 robots.
Topics128,109
Posts1,056,267
Members48,439
#1287576 11/15/2018 10:00 PM
A little help please. Does the ignition switch wire connect to the positive or negative side of the coil? Tkx
+ to the switch. - to the points. The coil will work wired backwards, but, not as well. The windings in the coil are insulated from the can outside. So it will not short out. The coil is wound in a manner that reversing the current flow may reduce the output voltage(efficency) . That is an "Engineer" convesation that we can avoid. The last conversation I got stuck in like that was about "hole flow". Look it up if you need to. Still makes my headake after 50 years.
Steve H
That’s interesting Steve. I never knew it made a difference which side the ignition was wired to. I learned something today!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Just to muddy the waters a little more- - - - -the real culprit to reversed coil polarity is "inductive reactance"- - - -the resistance to current flow in the primary coil winding if the end of the secondary coil winding is at the distributor side instead of the ignition switch side.
LOL!
I've never thought about too much coil polarity. Just hooked it up the way it was supposed to be. I got curious and wondered why? Stumbled on this, and now it makes sense. Tesla would have known that for sure too.
http://mgaguru.com/mgtech/ignition/ig104.htm
Insomniac
Insomniac
Thanks 4100. Inquiring minds like to know! thumbs_up
Gord 🇨🇦
1954 1/2 ton 235 4 speed
