6 members (klhansen, walterhvogel, Barry Martak, amtrakjoe, GusG, 1 invisible), 71 guests, and 3 robots.
Topics128,089
Posts1,056,419
Members48,443
I have a 1947 GMC 300 with a 248 in it. I currently have a GKT-134 crash box in it.
Do I have any other options?
Im basically trying to decide whether I should keep the 248. If I can bolt up a more practical transmission that would allow me an extra gear or higher gears then I think I justify keeping the stock motor. Im just looking for a little extra speed. (55-60)
Thanks!
Logan
2010 Silverado 2500HD
1947 GMC 300
3B Offline
Hy47GinPole, I know some of the larger GMCs used Clark transmissions 205V and 207V if I am remembering correctly, I'm not sure if a bellhousing change was necessary to install them or not. The Clark transmissions are "crash boxes" and they will not help increase your speed unless you find a rare overdrive version, 205VO or 207VO, hope that helps.
A more modern overdrive option is the New Venture 4500, which can be adapted to fit, this may no longer be an economical option, they're getting old now.
•1952 Chevrolet 3800 pickup
---All pictures---
Crusing in the Passing Lane
The 248 will also drive a S-10 trans with an OD high gear, need make sure brakes and steering are up to higher speed, though.
Ed
A 300 size GMC is more truck than a T5 from an S10 should tolerate.
I’d look for a transmission used in a 1 ton or perhaps larger.
---All pictures---
GM 14 bolt axles give a variety of higher ratios, easily fit( look at Grigg's 14 bolt notes) are inexpensive, easily found; however, make sure your 248 can pull higher gears, might be a good excuse to fit a 302. Higher cruise speed might require upgrade to brakes, steering system.
Ed
Is taller tire height an option for a GMC 300? That would help.
What exactly does it take to do a NV4500 swap? Does the adapter have to be custom machined?
Also taller tires arent really an option. Its got 8.25-20's on it now which measure out around 37"
Logan
1947 GMC 300
Start a new thread about an NV4500 swap, with a good title those that have done the swap will notice and chime in. Also search for past threads. Also look at “Advance adapters” they may have an adapter plate.
Several versions of the NV4500 exist, and they will adapt slightly differently.
---All pictures---
