Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (TUTS 59, Peggy M, Gdads51, 68ironhead, tclederman, 2-Ton, wilbur53), 154 guests, and 7 robots.
Topics128,281
Posts1,058,476
Members48,490
#1286271 11/05/2018 10:44 PM
My overdrive was singing and noisy so I pulled it out and put the old 3 speed back in. I purchased a rebuild kit from cobra transmission and am about to attempt the rebuild. The question is do you also disassemble the overdrive unit or just rebuild the front half . It worked fine but it was very loud.
You will need to disassemble the entire unit. There are 3 bearings in an overdrive transmission. The center bearing is on the mainshaft which is integral to the overdrive components. The rear bearing is on the rear shaft which contains the planetary ring gear. There is a good break down in the 55 factory shop manual available from numerous aftermarket sources. There are numerous posts on his site regarding this subject. We are here to help. Fred
thanks for the info. I will get started after I get a manual.
