7 members (papas52, klhansen, Shade Baby, 1955 1 Series, Still At It, Bill Hanlon, 1 invisible),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,161 Posts1,056,906 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | Another way to deal with the removing the paint from the high spots on the horn button is to tightly roll a blue paper shop towel and hold it together with tape. Think of it as an eraser stick and use acetone on it to remove the paint from the high spots as soon as the new paint becomes tacky. I would do it twice, once after the primer and then again after the final paint.
Carl
| | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | That's a good idea Carl - Thank you very much! | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Tom,
You will not hurt the side of the horn button with a screwdriver. More are concerned with putting small dents into the edge of the steering wheel next to the button. The tabs are approximately in the
2 o'clock, 6 o'clock & 10 o'clock positions as you look at the button. I would apply pressure in those three areas. Once you remove the button you will see the three mating tabs on the internal button.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hi. Do you think that's why the three tabs are there - as like the prying points? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Wow, I can’t believe we’re into 2 pages on removing a horn button. Just get your screwdriver and do it like all of us have done. It’s not rocket science. Take it off and move on. Speaking of moving on, that’s what we are going to do with this thread.
