1 members (NJC), 132 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
Page 2 of 2 1 2
Another way to deal with the removing the paint from the high spots on the horn button is to tightly roll a blue paper shop towel and hold it together with tape. Think of it as an eraser stick and use acetone on it to remove the paint from the high spots as soon as the new paint becomes tacky. I would do it twice, once after the primer and then again after the final paint. Carl
That's a good idea Carl - Thank you very much!
Tom, You will not hurt the side of the horn button with a screwdriver. More are concerned with putting small dents into the edge of the steering wheel next to the button. The tabs are approximately in the 2 o'clock, 6 o'clock & 10 o'clock positions as you look at the button. I would apply pressure in those three areas. Once you remove the button you will see the three mating tabs on the internal button.
Craig
Hi. Do you think that's why the three tabs are there - as like the prying points?
Wow, I can’t believe we’re into 2 pages on removing a horn button. Just get your screwdriver and do it like all of us have done. It’s not rocket science. Take it off and move on. Speaking of moving on, that’s what we are going to do with this thread.
Page 2 of 2 1 2
