| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Dumped off a load of firewood today to a lady down the road. "Gert" my 1942 second GI Chevy project did what she is was made to do... Pretty cool that old iron can still work even after 76 years.
https://www.youtube.com/watch?v=KY5emKPwGiY
Here she is same place last year...making some headway in the restoration.
https://www.youtube.com/watch?v=QO8gnFwqd2E
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Great truck, great video.
1951 Chevy Panel Truck
| | | | | Joined: Sep 2013 Posts: 1,362 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,362 | Sweet. Good Job on keeping the old truck in using shape.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thanks guys. The cylinder ram and pump on this truck run like a Swiss watch. All that was required was a fluid change and repacking of the cylinder and actuator valves. I was reluctant to open up the one-piece integral pump/ram system as everything inside is made of unobtainium. The PTO driveline was a different story as the PO repaired it with all sorts of non-functioning cobbled junk. With a bunch of head scratching/measuring/searching, I was able to source oddball (13/16 diameter) driveline parts to make a darn smooth and quite running driveline.
Paul | | |
