5 members (Mike B, Shade Baby, Randy Baumann, Ponchogl, Danielbolt), 72 guests, and 2 robots.
Topics128,154
Posts1,056,856
Members48,456
Page 1 of 2 1 2
Hi there - how do I take off the horn cap correctly?
V
V Offline
It pry's straight off.
From the sides; with a flat tip screw driver?
Pry it up with whatever you can get under it. The retention is in the center. Mine has been off enough that I can remove it with my fingers.
Fred
52 3600
69 C-10
I just want to be very sure guys because I don't want to damage the cap with bended sides and such.
Tom, You probably have the standard horn that looks like the photos below. This is what it looks like on the inside.
Harold
Does the cap just snap back on?
I'm talking about the horn cap on the steering wheel sir...
[quote=Toms49Panel]Does the cap just snap back on?[/quote] Yes.
Fred
52 3600
69 C-10
Thanks to all who replied. I just want to learn about these gems
[quote]I'm talking about the horn cap on the steering wheel sir...[/quote]
Sorry, I thought you asked about the cap on the horn. Here is a breakdown of the Horn Button. Your horn is the lower section of the photo.
Harold
Harold
Hi Harold, that's a great illustration
If your horn currently works, you might want to disconnect the battery before you start monkeying around with the horn button. Beep! Beep!
Craig
That is a great reminder about disconnecting the battery! My horn button was looking shabby so I was thinking of removing it to get a nicer one. Once I cleaned it up- it now shines bright like a mirror.
Awesome. Glad to hear it worked out. I have 4-5 chevy horn buttons strewn about the garage as decor. My daughter used one as a belt buckle while she was in High School. The good ole days.
Craig
I'm just curious: why did mine shine up like it's chrome? I thought they were supposed to be Brown?
I still haven't tried to take it off yet - I just shined it up while it's still on the wheel - I am so afraid of damaging it.
Wait!! You haven't removed it yet? Gonna take some pics of mine tomorrow. It might help.
Craig
That will be great! I am looking forward to seeing it. Mine looks chrome or stainless, but I thought they were Brown???
Fully chrome plated underneath accenting the "Chevrolet" and 3 lines underneath. Painted on top of the chrome, everywhere else.
Craig
What color is the painted insert?
Factory Chevy Brown?
The repro ones are interior color. I don't know if that is correct, but it sure looks spiffy.
I think that the standard interior color would indeed look pretty spiffy. Can you imagine how much work it would be to paint the entire surface and then wipe the paint off of the lettering and triple lines? Sounds like a fun winter project for me, especially since I have a couple cans of interior paint.
Craig
cmayna: here’s my painted horn button. The chrome on it was dead and the button had a few small dents in it. I sandblasted the button and worked out the dents. I then sprayed it with three lights coats of grey. Then I sprayed it with two light coats of black. Next came the tricky part: using some 320 grit, I wet sanded the lettering and the triple lines and the outer perimeter feature line, LIGHTLY AND VERY CAREFULLY and WITH VERY GOOD LIGHTING, sanding thru those two top coats of black to expose the underlying grey. I will admit that on my first attempt my sanding was too aggressive and I had to repeat the whole process, there’s a steep learning curve here to develop the technique to not sand those high spots too much. Once satisfied, I shot the whole horn button w two coats of clear. It has held up perfectly....I did it about 5 years ago and I think it still looks pretty good as you can see by the picture I just took. It was a good winter project, took some time, and at least one 12 pack. [url=https://flic.kr/p/2cB4WkN]Painted Horn Button[/url] Good luck, Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
[url=http://https://flic.kr/p/2cB4WkN]Painted Horn Button [/url]
"Old Blue"
More pix on Flickr
Hi dave, I'm touching your link but it's not connecting...
Nevermind, I was able to click on your Flickr link. The horn button looks great!
So how do you take off the horn button guys?
Tom thanks, sorry about the link, I’ve posted pictures before but I must be doing something wrong....maybe one of the IT guys can help?
Painted Button
"Old Blue"
More pix on Flickr
Tom, take a small flat blade screw driver and pry in the gap between the outer edge of the metal Horn Button and the rim of the steering wheel; carefully pry the Horn Button upward toward yourself, it should come up and out.
"Old Blue"
More pix on Flickr
And if your battery is still connected you might want to unhook it first. Beep! Beep!
"Old Blue"
More pix on Flickr
There are three ears on the back side of the nuttin holding into a recess in the wheel.
"Old Blue"
More pix on Flickr
I am afraid of damaging the sides of the cap
I can see your pictures now, they look great. I guess the only way to do it is to just do it. Does it just snap back on? Do I need to line up the three ears....?
Tom, if it hasn’t been removed in a loooong time it might fight you when you try to remove it. Pry from several different spots. It’s should come loose without damaging the Button. You might want to try to protect the edge of the plastic wheel from damage from the side of the screwdriver. Alignment during re installation is determined by the odd shape of the horn button. “Just do it!”
"Old Blue"
More pix on Flickr
Thank you sir. Your pictures turned out great. Your horn button turned out very nice...
I will Try ! 😇
.....and yes it just snaps/pops back in... good luck..
"Old Blue"
More pix on Flickr
Thank you sincerely.
Page 1 of 2 1 2
