| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 34 | I’m about ready to fix the floor of my 66 C 10. I need to replace inner and outer rocker panels and a lot of the floor. I don’t have a mig or tig and so I plan to lap braze the whole thing together. Someone told me I should take the doors off and braze pieces of angle iron across the door opening to keep it from contracting so that the door will fit when I put it back on. So my question is… should I take the door off and add the angle iron across the door opening or will it be OK without the angle iron? | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | If you have a torch that you are going to use to braze with, you would be a lot better off to gas weld than using brass. Brass will not hold anywhere near as strong as a weld. Just a suggestion. Probably be a good idea to use something to keep the door opening in place when doing it whichever way you do it. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Dec 2001 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 34 | Thanks for the advice Wrench Fetcher | | |
