0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#128541 10/09/2007 1:10 AM
I’m about ready to fix the floor of my 66 C 10. I need to replace inner and outer rocker panels and a lot of the floor. I don’t have a mig or tig and so I plan to lap braze the whole thing together. Someone told me I should take the doors off and braze pieces of angle iron across the door opening to keep it from contracting so that the door will fit when I put it back on. So my question is… should I take the door off and add the angle iron across the door opening or will it be OK without the angle iron?
#128542 10/09/2007 2:22 AM
If you have a torch that you are going to use to braze with, you would be a lot better off to gas weld than using brass. Brass will not hold anywhere near as strong as a weld. Just a suggestion. Probably be a good idea to use something to keep the door opening in place when doing it whichever way you do it.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#128543 10/09/2007 11:57 PM
Thanks for the advice Wrench Fetcher
