2 members (rfs56trk, Donf),
92
Mod | | | Forums66 Topics128,281 Posts1,058,488 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | I think you're on to something. Without reading all the other posts, could oil pressure and temp be substituted? | | | | | Joined: Mar 2014 Posts: 4,524 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,524 | Yes, you could do that but you might have to get more creative. Here's the deal: those two gauges are larger than the mini-tach and mini-vacuum gauge I used, so you would have to (1) use the stock AD speedo case (2) mount the gauge parts on the back side of the speedo case (3) remove the needles on there currently (4) fabricate long shafts to lead from the gauge stems to where the new stems will be. It won't be necessarily easy but it can be done. You could also install an exhaust gas (AFR) analyzer if you wanted to know if you're running too rich or too lean. But you would need to use the speedometer out of an S10 to get the 0 to 80 range in a 180 degree sweep.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Dec 2019 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2019 Posts: 36 | I am looking for a S-10 T-5 mechanical speedo tail housing. Can buy a new one on line for 229.00. Hoping to find one at a swap meet for less then that. | | |
