| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#1284 03/10/2003 12:34 AM | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | I'm really enjoying my truck but have had an ongoing drive line noise/vibration problem that may be related to a u-joint angle problem. I installed a camero 5 speed behind a 261. I left the long tail shaft on because I had the room. I shortened the front driveshaft but all this changed the angle from the carrier bearing to the trans. tailshaft. I installed two wedges between the carrier bearing and the frame member it is mounted on but I think I need more correction. Here is the question: if I raised the front of the engine by adding a spacer to the engine mount would I hurt the running of the engine?(oil pump, or...) Is there an easier way to corrcet tha angle that I am missing? Thanks, Don. | | |
#1285 03/10/2003 10:16 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You won't be able to raise the engine by much before you cream the radiator with the fan. So it won't hurt the engine, but the rad may not like it. But you should be able to do something else with the driveshaft.
#1286 03/10/2003 12:04 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Are the two piece drive shafts installed correctly? That is the center u-joint should be 90 degrees out of phase with the two end joints. | | | | | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | Thanks for the ideas. The radiator thing was pretty obvious after just a little thought! Here is how I solved this problem: I cut 3/4in. off of the carrier bearing "carrier" which raised the front driveshaft a lot and only changed the angle of the rear shaft a little, resulting an almost lined up pair of shafts and the noise and vibration are gone. | | |
