1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Hi guys,
So I think i'm at the stage of putting a coating on my bare metal truck. If I put etch primer on all the parts (after proper prep), but do not put a coat of high build or whatever on top right away will I get rust under the etch? As in, is the etch primer weatherproof? Will I have to sand it off before I put high build on in weeks, months??? The truck is staying in the shop and won't see any moisture or drastic temperatures. Am I even looking at this the right way?
Thanks Colin | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Colin,
I sure hope you're looking at it the right way because that's how I looked at it. My cab is on a dolly in my garage, out of the weather dressed only in etch primer. This stuff isn't very durable, but it's OK inside and dry.
You don't want to sand through it before you spray it with your 2K primer. Maybe a light scuff with a 3M pad.
I think the absolute best way to do this, in hindsight, is to blast and prep, etch prime and then immediately cover with a good 2K primer.
Any subsequent bodywork can be done through the 2K...Bondo included. It's common practice to apply body filler over the 2K, So why not let the truck sit in the shop in more than etch...finish it with 2K...it's then bullet proof.
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | epoxy prime the bare metal, epoxy doesn't need the etch and it's a sure seal that will prevent rust till you get back to it
Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Colin, What Bill said is true..clean bare metal doesn't actually need a etch primer under it. I blasted my cab, but wanted the added rust protection the etch primer provided in case I didn't get all the metal 100% bright. Many folks skip the etch primer and shoot only the 2K...I must be a nervous sort! Stuart | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thanks guys,
It was all blasted and stripped down probably close to a year ago. I would have to go over all the blasted parts again i'm thinking. Also, the exterior is covered in rust pits (from the PO 5 years ago). The surface rust was all sanded off and the rust pits are still there. Am I right to assume they must all be blasted out?
Thanks again, Colin | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Colin,
As you know, any rust left behind will usually breed more rust. The etch primer will address light surface rust, but that's it. Clean and bright is the ticket for success. Can you blast the problem areas with a syphon blaster on a individual basis?
Stuart | | | | | Joined: Jul 2007 Posts: 17 New Guy | | New Guy Joined: Jul 2007 Posts: 17 | On my inner fenders I found my finger prints in rust two days after I brought then home from the blaster. They looked clean and bright when I picked them up. Another two days passed before I got time to get back to them and they had more rust popping up. Used a flap disc on my grinder to clean them off the rust then used Jasco Prep & primer on them. been a couple of weeks now and they still apear rust free. | | |
