9 members (klhansen, rfs56trk, Bill Hanlon, 1955 1 Series, DHedrick, Otto Skorzeny, 39Master85, greenie-reddy, Peggy M),
136
Mod | | | Forums66 Topics128,087 Posts1,056,399 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | So i went to change the oil in my 283 in my 56 chevy (not original to the truck - it was out of a 67 chevelle i believe). It has the old canister for the oil filter and the gasket was stuck way up in there, so far i couldn't get it out. It was almost as if it had creeped in behind/underneath the valve (the metal piece between the canister and the engine that has two bolts connecting it to the engine). Has this happened to anyone else? What a pain. The engine was recently rebuilt and this is my first oil change since the rebuild. Anyway, just curious if this is a common issue with those old style canisters. I'm looking to put on the spin on adapter to make this a much easier task down the road! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Over forty years ago when I was working part time in a garage, I was taught to remove that ring with a dental pick type tool. If it was in good shape we left it alone. You would be much happier with a spin on setup. | | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | I was going to attempt that, but it is so stuck up in there, i'm not sure that would even do the job. How big a deal is it to remove those two bolts holding the "valve" piece in there between the engine block and the canister? I tried it with a socket, but the space between the bolt and a metal lip next to it prevented that, so i may have to find a thinner socket to fit in there. What fun. I would hate to attempt to get it out with a pick, destroy the gasket, and then find out i really have a problem now with trying to get it out. Otherwise i could just change the filter and reuse the gasket already in place. It looks to be in good shape as is. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | You can remove the valve assembly to get the gasket out. It was a common practice back when all of the Chevy V-8's had the canister type filters. Either way is acceptable. Fred
| | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | OK thanks for that clarification. | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Once the bypass valve is removed, a small putty knife or a gasket scraper removes the O ring easily. That's how I was taught to do it when I got my first job outside the family shop in 1962, pumping gas and doing oil changes and tire repairs at a Shell service station. I worked after school 5 days a week, and had alternate Saturdays or Sundays off on the weekends. Kinda rough on the social life, but I had a 47 Ford business coupe to feed and insure! It wasn't uncommon to find two gaskets in there! Jerry
| | | | | Joined: Jan 2017 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 124 | Same here, worked in a garage 50 some years ago before going into the service. My boss had made a removal tool from an old broken screw driver and the bench grinder. Worked pretty good for the most part. Taped it a couple times with a hammer to cut through the gasket, then work it around prying it out. most of the time if the gasket was still pliable you could grab it and pull it out. The ones that were a real pta were the ones that had not been changed in a long time and gotten hard as a rock, those come out in little pieces.
38 Chevy 1/2 ton being resto-moded 65 AC Cobra replica USAF vet
| | | | | Joined: Nov 2004 Posts: 2,417 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,417 | I had a '67 Chevelle (283 canister filter). Never had a problem. Although that was 43 years ago.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A new seal comes with the new filter.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | It wasn't uncommon to find two gaskets in there! Jerry Or a gasket & a half!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | I always change mine to the spin on type because my first one would not stop leaking. Probably because it had old gaskets and permatex stuck in there. But, obviously that is not "original" for the purists.
