4 members (D B Cooper, Bill Hanlon, LAROKE, 1 invisible), 103 guests, and 1 robot.
Topics128,095
Posts1,056,072
Members48,433
I am new to this forum. I recently purchased a '48 GMC Pickup with the 6 volt posite ground system. I will be converting to 12v. I also bought a factory wire harness and plan on rewiring the truck. I'm interested in switching to a negative ground system. What is required to do so?
Fox Offline
https://www.stovebolt.com/techtips/12_volt_conversion.html
Everything you need is here. Check out the rest of the tech tips on the homepage. You may likely never post a question again! 😎 They are very good. Welcome to Stovebolt!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
