1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I was out at Gateway's showroom today and stumbled on this old gem. I remembered in one of many conversations with Dave, on these old trucks, that he mentioned a 3800 yellow restoration that he did for a fella near me. I never saw the truck on the road or at a local show, but it sure is nice. Now I'm not sure it's $63K nice, the old boy probably spent that much with Dave and is trying to recover his funds, and maybe he will if he finds that one guy that needs it for his collection. I wouldn't bet the ranch on it though. Anyway have a look, he did a nice job. For those folks that don't recognize the name, Dave owned the Hollister road company here in Houston and he offered a front wheel disc brake kit for 3800's. He passed away earlier this year, and will be missed. Big yellow 3800
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | 292 motor ? 14 bolt rear ?
| | | | | Joined: Sep 2013 Posts: 1,366 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,366 | Nice truck, I'd describe it as nicely restored with tasteful upgrades for power, comfort and safety (ac, modern wheels and tires, 4 wheel disk brakes with parking brake, power steering, seat/shoulder belts). What's not to like, just needs to be driven,,,,to my house. And about 40k less expensive.
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | Nice RestoMod. I would be afraid to take it on the road after spending $63k on it!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...I would be afraid to take it on the road after spending $63k on it! People do it everyday, check the price on a fancy new 1 ton pickup. That is a nicely done truck. Other notable features, 17" tubeless tires and wheels? SM465 transmission, 54/55 model engine/transmission crossmember. It does look like a later model 14 bolt axle, which would have faster gear choices then even 4.10 if needed. As nice as it is it could look even better with careful attention to detail on hose and wire layout, and the rear driveshaft is possibly to short, extended past the missing slip yoke dust seal. | | | | | Joined: Nov 2005 Posts: 324 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 324 | Nice truck. Interesting that the floor lever for the parking brake is attached to a cable, and the ID tag is on sideways? I also notice the wiper switch on the dash, I wonder if it has vacuum wipers, or is there a dash mounted switch available for the electric motor? | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I agree Ron. Would love to have it. Did you guys notice that fan control on the firewall. Never seen one of those, but I'm going to research for my vette. I've never had a problem with my stovebolt engines running hot. Can't imagine the A/C has that kind of an impact. Also did you notice the extensive brake dust on the inside of those rims. Either real cheap pads, or someone has a heavy foot.
