| | | Forums66 Topics128,131 Posts1,056,373 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Guys, can you folks that know OMNI paints can you check me on my plan here and give some advice? Please?
I have most of the truck in epoxy primer(MP170) and has been for 3 months. I am ready to paint some of the areas where I am using a urethane one step (MTK AU) and thinking that I can just wet sand that epoxy primer and re-coat it with epoxy. Being this area is pretty smooth I was planning to just shoot the MTK right over that. Will it be OK to shoot that MTK over the 2 coat of epoxy with out sanding and stuff if it does not need it assuming that it has been with in 3 days? Or... Should I wet sand this with 400, shoot a coat of epoxy then coat with MP282 HB 2k primer, wet sand and then spray with the MTK?
Or... Should I, Wet sand the epoxy, shoot MP282 HB 2k primer, sand and then shoot the MTK?
Sorry for the ramblings... any help would be greatly appreciated.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | as a rule i always sand befor putting on any coating even if u have already sanded it monthes ago if it is the last coat u are going to put on before paint 400 will work great mp2k builds nicly so u could even sand it with something rougher no more than 180 just to nockit down fast than finish withn400 it was late when i typed this so let me no if u have n e ? sometimes things i do after midnight only make since to me | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | if it is smooth you can jsut scuff it w/a Scotchbrite pad for some stick for the new coats. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Check the PPG product sheets. As I recall, you could rough-sand the smooth panels and use a surfacer or sealer/surfacer, let it quickly dry and then, without sanding, spray your finish coat(s),
The safest thing to do is to check the PPG product sheets for the products you are using. | | |
