2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1280431 09/16/2018 4:40 PM
Is there a simple test I can do to see if all cylinders are fireing whilst the engine is running.Can you tell by the sound if one is not fireing on a V8.Thanks in advance.
You can remove one plug wire and see if it stumbles. Put it back on then try another.
Dennis
40 Chevy 1/2 ton
Moderator, Electrical Bay
Or before you do that you could hold the palm of your hand about 1/2 inch away from your exhaust pipe while it is idling. If one isn't firing you will feel a distinct and evenly spaced "puff, puff, puff" feel and then you can narrow down the problem cylinder.
~ Jon
H Online: Content
A little more accurate procedure than just pulling plug wires is called a "power balance test". It takes an accurate tachometer and a vacuum gauge. Set the speed to a fast idle, maybe 1000-1500 RPM and monitor the manifold vacuum. (NOT distributor vacuum- - - -tap into the main plenum under the carburetor. Each time you disconnect a plug wire, record the RPM drop and the vacuum change. In some rare instances involving burned intake valves or a sticky EGR valve, the RPM might actually speed up when a wire is disconnected. Usually, disabling a good cylinder will cause a drop in RPM and vacuum, while disconnecting a low-powered or dead cylinder will not have much of an effect. If you also happen to have an exhaust gas analyzer connected, you'll see a rise in unburned hydrocarbons when a good cylinder is disabled.
If the engine has headers, you can use an infrared thermometer to test for a cool/cold cylinder.
SimS
what Jerry describes is how modern cars via OBDII monitor and report on misfires (P0300-0310 codes)
If you suspect it, it's probably got a dead hole.
Throttle response is slow with some engine shaking - which gets worse with more load?
On my 216s, I have used a household wire tester that is meant for identifying live wiring and outlets. I hold it near each plug and I can watch it firing. The first time I used it looking into a bad miss at idle, it didn't light up on #5. I replaced the wire with no difference observed. I replaced the plug and it lit up on 5. It was a shorted plug.
1951 1 Ton Completed
Ok one more suggestion... If the problem is spark related you can check each wire with a timing light.. If one of the wires doesn't cause the light to fire then you have an ignition issue leading to that cylinder..
1953 3100 Mariner blue (some anyway)
If you have a shorted plug like I did, the timing light will flash regardless.
