7 members (Gdads51, Lightholder's Dad, ShopRag, Hotrod Lincoln, sudsyz, Chip O, 1 invisible),
77
0
Mod | | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | I am a long way from being to the stage of doing this but was wondering if anyone had plans/dimmensions on how to make the wood floor for my truck which is a '50 3100 shortbed? I have the lumber and the tools but don't have the dimensions, and/or steps for drilling the mounting holes, including the offsenter washers so I thought I would check with the experts! Many thanks in advance. Also curious what kind of routing detail I need on the edges for the metal strips to sit into.
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | That is awesome. Thanks. I saw that document mentioned and even went to their site but could not find it. My only question is how to measure the side boards, but that may be easy enough to figure out once I get the bed assembled again. If anyone has other tips/tricks please share! Thanks!
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jason, You could not find anything at the links given above by Grigg?The first link has measurement information that is somewhat confusing/complicated, but it is something. The second link goes to a page with a lot of information, including Grigg's first link. | | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | It is nearly everything I need, and actually may be all I need but I don't know for sure. It seems the edge boards would be slightly different with the way the rail strips attach to the side panels of the bed and it doesn't mention that.
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | | | | Joined: Jul 2000 Posts: 2,208 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,208 |
Gord π¨π¦ ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks, thatβs better info. | | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | I probably aready know the answer, but here it goes anyway. Is there a router bit available that would do the edge cuts? Iβm always for the easy way! Jim | | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | In looking at the drawings, it seems fairly straightforward. Use a 3/4β straight bit (dado bit) and enough passes each to reach the shallowest needed dimension. A fence will be useful to guide the router base and likely need be moved to achieve the required width. Then use a narrower straight bit, adjust the cutting depth as deep as needed to meet the drawing dimensions. As you likely know the depth of cuts for the deep and shallow dimension will best be achieved in increments. Cutting a deep cut in one pass can be done, but likely result in tear out and/or other frustration easily avoided by taking multiple passes at increasing bit length.
An alternative approach would be to use a table saw and adjust fence and blade depth as needed. That likely would be my choice for speed and cut quality.
Both options will achieve a quality product if the boards are dry, straight, knot free, without bows, twists or other defects. | | | | | Joined: Jul 2000 Posts: 2,208 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,208 | Our boards were milled at my neighbor's fully equipped wood shop. I asked about using a router table. His recommendation was to use the table saw with dado blades and that's what we did. He had a gadget with rollers on it to hold the board down and against the fence.
