4 members (78buckshot, JW51, baldeagle, moparguy), 85 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1279552 09/08/2018 6:14 PM
I have a 51 that's been converted to 12 volt. My headlights are not as bright as they should be and my taillights are not very bright. I am running v-8 and running a high amp one wire alternator. Tail lights are original 51 tail lights. Help would be appreciated. Thanks.
hebert2756 #1279555 09/08/2018 6:21 PM
Check for voltage drop across the contacts of the headlight switch and the dimmer switch. Dirty switch contacts can rob a lot of voltage before it gets to the lights. Ditto for grounds, particularly back at the tail lights. Running relays to the headlights takes a lot of load off the switches. It's very noticeable on 6 volts, but there will also be a difference with 12V headlights.
hebert2756 #1279567 09/08/2018 9:26 PM
Thanks will check that. Brand new switch but will check ground.
