| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2016 Posts: 47 | I have a 51 that's been converted to 12 volt. My headlights are not as bright as they should be and my taillights are not very bright. I am running v-8 and running a high amp one wire alternator. Tail lights are original 51 tail lights. Help would be appreciated. Thanks. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Check for voltage drop across the contacts of the headlight switch and the dimmer switch. Dirty switch contacts can rob a lot of voltage before it gets to the lights. Ditto for grounds, particularly back at the tail lights. Running relays to the headlights takes a lot of load off the switches. It's very noticeable on 6 volts, but there will also be a difference with 12V headlights. Jerry
| | | | | Joined: Jun 2016 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2016 Posts: 47 | Thanks will check that. Brand new switch but will check ground. | | |
