2 members (Gdads51, MNSmith), 80 guests, and 5 robots.
Topics128,181
Posts1,057,152
Members48,464
#1279161 09/05/2018 4:46 AM
The body is off and on the rotisserie. Worked out pretty well. Thought I'd share some photos with you guys.
First is the brackets bolted in the door frame. Second is ready for liftoff.
klhansen #1279162 09/05/2018 4:51 AM
3. Cab off frame.
4. Setting up rotisserie parts.
5. Lowering on to rotisserie - a bit front heavy (pivots located at geometric center, not the center of gravity)
6. Another view
klhansen #1279164 09/05/2018 4:53 AM
7. standing on it's nose
8. View of the bottom
Should make welding in patch panels easier on the back.
klhansen #1279185 09/05/2018 12:33 PM
That should do the job. Most I have seen locate on the firewall and back of the cab to rotate the other axis. If you don’t have to rework the hinge areas for rust it will be great. Great work. Now get after it. chug
klhansen #1279224 09/05/2018 6:59 PM
I wanted to avoid going the other axis because the cowls were so far gone. I thought I'd have a better alignment with the brackets on the door hinges and strikes. Very little repair needed at the lower end of the A pillars, so this should give me good access for repairing that little bit.
klhansen #1279245 09/05/2018 10:26 PM
I really like this!
-David
1953 2-Ton GMC
klhansen #1286757 11/09/2018 5:27 PM
I got a lot of great info from these posts. Thanks to all of you guys. I love the rotisserie idea. I have 2 engine stands, although one is in use right now. I will be building either a rotisserie, or at least a mobile platform to move the cab around on. I'm surprised to hear that the flange tool is such a bad idea, but I do see the reasoning behind it. Thanks to all of you guys.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
klhansen #1287503 11/15/2018 3:19 AM
Former Workshop Owner
Looking good.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
klhansen #1288263 11/21/2018 6:12 AM
If you are building your own keep in mind that 3" tubing fits inside 3" pipe for your pivot point.
mick53 #1288266 11/21/2018 8:25 AM
I used a couple of engine stands because a bunch of the work was already done. Easier and possibly cheaper than digging up the parts to fab everything. At least I thought so. The stands I used were $50 each shipped to me in Alaska, which is a smoking deal.
klhansen #1317268 07/10/2019 11:30 PM
Now that's what I call thinking outside the box. Nice set-up!
