3 members (60steve, sron48, dt235sd), 173 guests, and 5 robots.
Topics128,204
Posts1,057,288
Members48,467
Is there a way to tell by looking from the outside if a Chevy has had an engine swap to a newer engine that has insert bearings?
1950 GMC 1/2 Ton Long Box
228-Zenith carb- SM420-bendix brakes
V
V Offline
Yes. The serial number stamped on the block will identify the size, year and where manufactured and from that info it can be determined if the engine is a full pressure engine with insert bearings or an earlier splash/pressure engine with babbitt bearings.
The side panel size is another indicator but it's not fool proof, the engine serial number is the best way to tell next to dropping the oil pan.
Good luck
If there is no oil distributor cover on the left side of the engine, you have insert bearings.
unless the rods have been converted by someone else.
