4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
#1278945 09/04/2018 12:14 AM
Anyone have a stereo in their stock AD with 6 volt?
I have a 6 to 12 converter with a digital media receiver. Same as a CD player without the CD player. Just two speakers.
Stereo mounts in the removable console I built with the speakers under the bench seat.
Is this going to be okay on my stock 6 volt generator?
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
H Online: Content
What's the current draw on the 6V with the converter operating? Unless you're running some speakers with an obscene wattage rating, you'll probably be OK. Another approach to power the system might be one of the small gel cell 12V batteries and a trickle charger, and/or a solar panel that can be used for a recharge of the dedicated battery when the truck is parked. That would allow you to run the sound system for several hours at a time, completely independent of the 6V charging system, and put no stress on it at all.
Like a house battery in a boat. I have considered that route. Certainly could find a place to mount the battery.
The converter is rated at 10 amps continuous 12 amp peak. Can’t find anything on the stereo media player but it’s all digital and doesn’t play CDs. I have a small smart charger permanently mounted in my truck so I maintain the battery anyway.
Thx Don
In my quest to keep it stock. This was my latest hurtle. 6 volt converter works great. I’m not noticing any difficulty keeping my battery up. I installed everything so I can have it completely out of site for car shows. It also really looks bad when placed in a 72 year old truck. The stereo is controlled with a remote and the XM unit is removed and placed out of site when not used. The stereo is a digital media player, no CDs. It’s only 4 1/2” deep.
It sounds just like a high end stereo should sound in a 55 gallon drum😉
Don
