| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | Sometimes when I try to start my 1950 3600 nothing happens as I press the floor button, other times it cranks right away. When it's misbehaving, I might try 20 or 30 times and nothing and then suddenly it works. Sometimes, I don't have the patience to keep stomping and I get out, pop the hood and use a tire iron to pry against the firewall and linkage and it fires right up. I suspect the contacts on the starter mounted switch have become eroded and I have bought a replacement switch but wonder if there is a way to adjust the travel on the starter button linkage. I seem to recall that I added some washers somewhere to help with this but there was no change on the spotty operation. Anybody ever have this problem and how did you fix it?
1950 3600 1951 4400 Gazz
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | A twist top off a Coke bottle is just the right size to slip over the push button on the starter switch. It's a band-aid fix, but it works. Check the pivot points in the pedal linkage for wear- - - -you'll probably find some oval holes and worn linkage. Also look for worn out brushes or a burned spot on one of the armature commutator bars. If it stops in the wrong place, the brushes won't make contact until the armature gets moved a little. Jerry
| | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | I think I have heard of the "repair" before but thanks for the reminder. Yes, I'm sure the holes in the linkage are bit wallowed out but that will have to remain for now. I am fairly sure that the starter motor itself is okay as it never fails to start with the tire iron method.
