5 members (TooMany2count, Otto Skorzeny, MickeyP, Wally / Montana, Bill Hanlon), 101 guests, and 2 robots.
Topics128,052
Posts1,055,729
#1278011 08/27/2018 4:47 PM
Is there any reason to save the pistons, crank and camshaft from a 216?
I have two 216 engines to haul to the scrap metal yard. Is there any value in these parts? It seems to me like a pain in the butt to remove the pistons and then store them indefinitely. I'm leaning towards letting them go.
The rest of the parts I removed. For some reason I don't feel too bad about saving the tin and the small parts. But to me the pistons, crank and cam kind of seem like junk.
Stove #1278067 08/27/2018 11:02 PM
back yard wrench turner
Offer them to your local car club. They are good for making trophies.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Stove #1278086 08/27/2018 11:59 PM
Send the rods to Jerry Hotrod Lincoln. He claims that he converts them to insert bearing rods for further use. I suspect that he just hoards them, but I have no proof of that. smile
The crankshaft and camshaft may seem like junk until someone needs one due to a spun bearing or needs a cam for a regrind. I have some of those in my possession for no other reason than posterity purposes. If someone should ever need them, they will be free of charge.
Carl
Small bearing journal camshaft cores like the 216 and early 235 cams are so scarce most cam reginders will only offer to rework a customer's cam if it's not worn too badly. If the crankshafts haven't been ground way undersize already they're also worth saving. The cast iron pistons make good paperweights unless you're doing a period-correct rebuild for some reason. Aluminum replacement pistons are a lot nicer to Babbit rods, as there's not as much inertia trying to pound the bearing material away. The connecting rod conversion I'm working on uses a Perkins diesel engine bearing which costs a fraction of what the regular stovebolt insert bearing conversion does, and allows a "worn out" reground crankshaft to be salvaged.
Crusing in the Passing Lane
There is always the 'boat anchor' avenue.
Ed
Ed
There is another well known manufacturer which has cornered the boat anchor market. They are the ones which have circled the cause of their problems.
2 Offline
hi Stove,
i private messaged you about this topic, but i will put it here too incase you don't see the pm and if someone else also can help me out
i could use a good 216 crank for a 1950 truck engine in Saskatchewan.
-s
