8 members (Gdads51, frogfarmer, Bill Hanlon, LAROKE, gswbbc, Forty9, 48jim1ton, Hotrod Lincoln),
107
0
Mod | | | Forums66 Topics128,043 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2018 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2018 Posts: 35 | Hey how’s it going guys. I was writing to ask if there were any differences in the frame on the 47-54 3100’s. I have a 54 3100 and the frame has a lot of rust on it. I know a guy selling a frame from a 48 3100 that looks to be in pretty good shape for $380. I was kinda thinking about buying it and restoring the frame, then when it comes time for my restoration I could just swap over the cab and drivetrain from my 54 onto the 48 frame. Would this work? Thank you! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Kyle S, as far as I know the kickup over the rear axle on the 54/55 chassis is much less than the earlier chassis, this requires different pickup box mountings (light trucks are not my area of expertise, but I'm pretty sure I'm correct about this difference and the one tclederman mentioned) hope that helps. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2018 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2018 Posts: 35 | Instead of adding transmission mounts and changing frame cross member, would I be able to take the ones off my 54 frame and put them on the 48 frame? If it’s all too much of a hassle I’m sure I could find a 54 frame down the road | | | | | Joined: May 2015 Posts: 11,017 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,017 | You wouldn't be able to duplicate the lower kickup of the frame rails over the rear axle without major surgery. And I doubt if a 54 bed would fit correctly on a 47-53 frame.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2018 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2018 Posts: 35 | Thanks for the fast replies! Looks like I’ll pass on the 48 frame. But I appreciate every bodies help, it’s great to have a forum like this | | |
