4 members (Jon G, Joe H, J Lucas, Phak1), 74 guests, and 3 robots.
Topics128,050
Posts1,055,646
Is there any reason not to use the master cylinder from a 52 half ton on a 50 or 51 half ton? The 51 and 52 masters are 1 & 1/8 bore where the 50s are a 1 inch bore.
This will be going on a 50 with Bendix brakes.
1950 GMC 1/2 Ton Long Box
228-Zenith carb- SM420-bendix brakes
Riding in the Passing Lane
The small bore will give more braking with less pedal pressure but will require more frequent adjustments. The Bendix brakes come on 51 up 1/2 ton models so the larger bore would match the factory setup.
1972 Chevy c10 Cheyenne Super
Crusing in the Passing Lane
While the smaller bore will result in less Pedel pressure like Wrenchbender says, you could run out of fluid volume.
Ed
