1 members (Shade Baby),
109
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | The lifters are probably worn concave on the bottom, resulting in a bell-mouthed condition that will make it difficult to pull them through the bore in the block. If so, both the cam and the lifters are junk. I'd suggest dropping the oil pan and using a long, thin punch to tap the lifters out from the bottom. Then use a straight edge such as the back of a new hacksaw blade to check the bottom of the lifters. If you can see daylight in the middle, pitch them, or have somebody with a lathe and a tool post grinder resurface the bottom of the lifters. There will be a corresponding radius worn onto the cam lobe, which also makes it unsuitable for further use unless it's reground.
Clean the head bolts on a wire wheel buffer and reuse them, no problem. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That engine has a lot of sludge and it needs a complete teardown, just my opinion! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its been a long time but it seems to me the lifters on that engine come out from the bottom. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Its been a long time but it seems to me the lifters on that engine come out from the bottom. George George, are you saying that (with respect to high-pressure 235 car engines): 1. the hydraulic lifters only come out from/into the bottom (downwards) 2. the hydraulic lifters preferably come out from/into the bottom (downwards) 3. the hydraulic lifters cannot (or, should not) come out from the top (upwards)? Are mechanical lifters handled differently compared to mechanical lifters? | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Nope- - - -mechanical and solid lifters both can be lifted out into the pushrod cover area. If they're mushroomed on the bottom they're too far gone to re-use but they'll still come out of the topside with a little persuasion. Lisle used to sell a tool that would expand into the top groove after the snap ring was removed, then the lifter was coaxed out with a small slide hammer built in, but I'm not sure it will expand far enough to get a grip on a stovebolt six lifter. The one I used to use was made for V8 lifters which are smaller in diameter. I'm also not sure the open area above the lifters would accommodate the length of that tool. I've seen oldtimers grind the jaws of a pair of vise grips so they will grip a lifter body and use them to coax a stubborn lifter out of a bore, also. https://www.napaonline.com/en/p/BK_7769248Jerry
| | | | | Joined: Apr 2018 Posts: 17 New Guy | | New Guy Joined: Apr 2018 Posts: 17 | First, thank you Jerry, George, truckernix, tclederman for all your replies. Got home, pulled the plugs. They look like they've been running too cold, but other than that they are all dry, no erosion or significant buildup. [img] https://drive.google.com/open?id=1p02ACadoDvJ7cIkQ4Wy33YktwOqirlx-[/img] Got the head off. There's a lot of carbon but I think the valves look ok. Don't see any chips or cracks and they seem to seat well. I don't have a compressor tool, and I can't find one locally so I can't get the valves out yet. But I am pretty happy with the head I think. [img] https://drive.google.com/open?id=1Z4x6An_0k_SLAU253kyPD6874ERS1yux[/img] Here is a map of the head bolts as were in the engine. I'm wondering if one of the manifold bolts was swapped, as they were stamped, and the M bolts were close, but not exactly like the F bolts. [img] https://drive.google.com/open?id=12xW11sslKvvJPwsnCwwIAFKEFIWgef9A[/img] The cylinders look good. I don't see any crosshatching, though it's present in the bottom below the rings. The walls are smooth. I cannot feel anything with my fingernails. There is a lip at the top, thinner than a fingernail, maybe 2-3 thousandths. Here is an example of the walls [img] https://drive.google.com/open?id=1cBPgDThn46pcaulr1vDetUZg1OeP1_66[/img] Here's the bottom of the engine with the pan off [img] https://drive.google.com/open?id=1SEPGyDbgSqgcZ0G7Yz2uXvCeztUM4vWV[/img] Here's the camshaft [img] https://drive.google.com/open?id=1GNA_FH81R0Oz4_5Pzcb5MBXrBXhMoT70[/img] [img] https://drive.google.com/open?id=1r0uai4e-sIWB2EucyibkqvwKpVj8SlZl[/img] Here's the bottom of the lifter that was stuck. Sorry, this was the best angle I could get. By the way, someone suggested in another thread to try a hose clamp around the lifter. That was pretty effective. I think if I'd been more persistent I would have been successful, but I was pulling off the pan anyway, and decided to wait. I can easily access them from the bottom and will probably tap them out if it comes to that. That tool, Jerry, would have worked in my situation also. I didn't know of that thank you! [img] https://drive.google.com/open?id=17xkXpmZOJP7Fi1xCvz27exhV8jFh4RvR[/img] Here's the sludge in the bottom of the pan. There is some grey precipitate, but it was buried and undisturbed. This is fine, but sandy. [img] https://drive.google.com/open?id=1B-ql6ZGU6SaA0RMqIAC66-0TmWmKu3-b[/img] Well. I have only rebuilt engines in event of a failure, and that was 15 years ago and my Dad was in charge. I have no experience that tells me what to do here. If this was a farm truck, or something I planned to just putter around town I would just clean it up, reassemble and drive it. But my wife and I want to drive it to Louisville, KY for the NSRA nationals which is 550 miles away next year. Of course we plan to make many short trips first. QUESTIONS: 1. I am really interested in what you guys think about this engine, and what you'd do with it. 2. Is there any point in pulling the piston rod caps or should I just leave well enough alone? 3. How in the world do I clean this gunk out? | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Well, you're partway there- - - - -have you checked the bottom of the lifters for wear like I suggested? I see at least one cam lobe with wear at the edges, and another one with what appears to be rust pits. Depending on your time and budget considerations, it would be to your advantage to go ahead and do a full rebuild, but that's going to involve at least a few weeks and around a thousand dollars worth of parts or more. If you get into cylinder boring, crankshaft grinding and cam and lifter replacement, the parts cost will at least double, and some fairly pricey machine shop work will also be needed. By all means, inspect the rod and main bearings for wear and oil clearance. Once I get as far into an engine as you are by now, I almost always go for the full rebuild, but I'm able to do at least 75% of my own machine work. About the only thing I have to farm out is crankshaft regrinding. Jerry
| | | | | Joined: Apr 2018 Posts: 17 New Guy | | New Guy Joined: Apr 2018 Posts: 17 | Would I be crazy to just clean it, put it back together and run it? I think the engine that's in it (and currently smoking but "recently rebuilt") should be closer to new than this one. I might have more success with that one.
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Its pretty dirty, but that state of affairs is also pretty typical for a 60 or so year old 235. I would look at the bearings and see what the condition looks like. If they are not terrible, I am not sure there is any downside to scrubbing that motor up really well, putting it back together and seeing what it does other then the time, effort, and a gasket set. These motors are pretty rugged in that respect and a lot have run in a lot worse condition.
the rub for you is that you are looking for the best of both worlds, scrubbing it up, putting it back together and reliability that would be sufficient to drive to the NSRA nats. You might get it you might not.
Mike
| | | | | Joined: Apr 2018 Posts: 17 New Guy | | New Guy Joined: Apr 2018 Posts: 17 | Well, the other reality is I'm in school and have no money right now. But I do have three 235 engines and I have access to Modern engines for cheaper than I can rebuild this 235. If I really want to rebuild this thing properly I'll have to wait until next year. The other engine I have was supposed to have a full rebuild and has less than a thousand miles on it since it's been rebuilt. The previous owner is a pretty competent fellow and it only started smoking after I got it. So if I can get this one to get me around town and the driveway I think I have a better chance with the other engine. | | |
