4 members (Hanks custodian, Otto Skorzeny, Steelonsteel, 2-Ton), 103 guests, and 2 robots.
Topics128,060
Posts1,055,837
Members48,427
#1276938 08/19/2018 8:11 PM
Hello, I'm currently tearing down a 261 out of a 1957 Pontiac car to put in my 1949 3/4 ton. Found some coolant sitting on a couple of the lifters at the back of the engine as per the picture. The oil I drained out actually looked really nice, wasn't any evidence of coolant in it. What does this look like to you guys? Crack in block by chance? After its torn down it'll be getting sent to a shop to be checked for cracks but if this is a red flag I'll probably be looking for a new motor.
Thanks!
http://tinypic.com/r/24fe538/9
Has the cylinder head been removed yet? If so, you're probably seeing a little coolant that dribbled down the oil return holes as the head was lifted off. Any machine shop worthy of spending money with will have a way of pressure testing the cooling passages. I used to make a couple of block-off plates for small block V8's with the pistons removed and the heads installed and plumb a garden hose into the cooling system if I suspected cracks. City water pressure in a block or a head finds leaky spots in a hurry!
Yes that'd explain it. Thanks for the quick response. Thought I should ask the pros before sinking a bunch of money into it at a machine shop.
