8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert), 99 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
so I'm going to be putting new shock absorbers in the 50 GMC half ton does anybody have any tips or tricks for making the installation go a little bit easier?
1950 GMC 1/2 Ton Long Box
228-Zenith carb- SM420-bendix brakes
They went on really well after I removed the cab on the restoration. Just make sure you hold the upper stem and dust shield from turning and then remove the nut, grommet retainer and grommet, then hold the bottom and stem and remove the nut the same way. Pretty easy, providing everything isnt rusted in place.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Installation is the easy part. Had to use the cutting torch to get the originals out.
Fred
52 3600
69 C-10
