| | | Forums66 Topics128,078 Posts1,055,940 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 33 Apprentice | | Apprentice Joined: Jul 2007 Posts: 33 | Hi boys, I have a rusty hood hinge on my 38 pickup its the right side. Whats a good way to loosen it up ? the left side works fine. Kind of weird being its just one hinge for both sides. | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I love PB blaster. what I do with very rusted stuff is I spray it down with the PB several times in the coarse of few hours. Just hit it with PB every time you walk by while doing something else. Then I spray it down one last time with PB, then take wheel bearing grease and brush it on lightly ( big glob works good) over the PB on the joint trying to leave as much PB as posible under the grease, and let sit over nite ( or a few days if really bad) This leaves a barier so the PB will not evaporate and lets it go to work. otherwise it will be dryed up the next morinig. I have had good results with this method, and gotten things loose that I thought were through aways. Good luck.
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Jul 2007 Posts: 33 Apprentice | | Apprentice Joined: Jul 2007 Posts: 33 | | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | When I redid my '40, I found some stainless steel rod that worked great as a hinge pin. | | | | | Joined: Jul 2007 Posts: 33 Apprentice | | Apprentice Joined: Jul 2007 Posts: 33 | Hey I like that. How did you get the old pin out ? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Mine were not too badly rusted. Soaked them good with penetrating oil, used an awl to tap out the pin far enuf that I could get it into a vise, then just worked and pulled at it till it popped. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Ooops...just reread your initial post. Are you talking about the top center hinge, or the top to side panel hinges ? The top center hinge has one side that nests into the other side - no hinge pins involved. In this case, as the other guys said - lots of rust breaker and patience. You might be able to buy a new hinge - Jim carter truck parts or ?? | | | | | Joined: Jul 2007 Posts: 33 Apprentice | | Apprentice Joined: Jul 2007 Posts: 33 | Ya I am talking about the top center one. | | |
