7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#127655 08/06/2007 6:16 PM
Apprentice
Apprentice
Hi boys, I have a rusty hood hinge on my 38 pickup its the right side. Whats a good way to loosen it up ? the left side works fine. Kind of weird being its just one hinge for both sides.
I love PB blaster. what I do with very rusted stuff is I spray it down with the PB several times in the coarse of few hours. Just hit it with PB every time you walk by while doing something else. Then I spray it down one last time with PB, then take wheel bearing grease and brush it on lightly ( big glob works good) over the PB on the joint trying to leave as much PB as posible under the grease, and let sit over nite ( or a few days if really bad) This leaves a barier so the PB will not evaporate and lets it go to work. otherwise it will be dryed up the next morinig. I have had good results with this method, and gotten things loose that I thought were through aways. Good luck.
1970 C50 dump! saving orphans from the CRUSHER
Apprentice
Apprentice
thanks guys
When I redid my '40, I found some stainless steel rod that worked great as a hinge pin.
1940 Chevy KC 1/2-Ton
Apprentice
Apprentice
Hey I like that.
How did you get the old pin out ?
#127661 08/07/2007 11:16 PM
Mine were not too badly rusted. Soaked them good with penetrating oil, used an awl to tap out the pin far enuf that I could get it into a vise, then just worked and pulled at it till it popped.
#127662 08/07/2007 11:22 PM
Ooops...just reread your initial post. Are you talking about the top center hinge, or the top to side panel hinges ? The top center hinge has one side that nests into the other side - no hinge pins involved. In this case, as the other guys said - lots of rust breaker and patience. You might be able to buy a new hinge - Jim carter truck parts or ??
#127663 08/08/2007 12:52 AM
Apprentice
Apprentice
Ya I am talking about the top center one.
