| | | Forums66 Topics128,090 Posts1,056,026 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | Hey guys, got a question for ya! I've got a 1955 first series that will be just the daily driver, ride around truck. I've blasted my frame and im ready to put some paint on it. I ordered some POR-15 from Jim Carter yesterday but just base coat not chassis top coat, my question is this. Do i need a metal prep before this, because they say you dont need a metal prep on the Jim Carter website? Also i was wondering if this could be a top coat for my chassis seeing how im not looking for a show truck. Thanks
Zach
- Zach Morris
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Check their web site. It'll offer the guidelines you need. www.por15.com
Drew
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If it's clean metal w/o any major rust, go ahead and apply it.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Por in my experiance appears to stick to anything (not oily) even me! I do like to metal prep when ever posible though. Just added protection. But I live in New England on the coast so we need every thing we can get.
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Por15 should never be applied to bare metal without using the Metal Ready. It was designed to be painted directly over rusty metal that has been cleaned but not removed. If you sandblasted the frame so that it's rough to the touch, you should be able to apply the Por15 with no problem. If you've blasted it to a smooth finish, you need to use Metal Ready. Metal Ready is designed to solve the problem of adhering to smooth metal by prepping the metal so the Por15 will stick. (If you have the money, I'd apply the Metal Ready anyway.)
As far as finish goes, Por15 will fade to a dull finish if exposed to the sun for a few days. If you don't mind that look, there's no need to paint over it. If you're going to paint over it, you need to prep it first, either by sanding the Por15 to rough it up or by using the topcoats they have designed to bond with the Por15.
The back half of my frame is done in Por15, and it worked fine but faded quickly. I've since painted over it with gloss black. | | |
