3 members (chevyb, Shade Baby, CuzzFuzz), 249 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
does anyone have any idea where I might be able to find an engine stand for a 228 GMC? I'm looking for something that I can use for long-term storage of an engine. Thanks in advance
1950 GMC 1/2 Ton Long Box
228-Zenith carb- SM420-bendix brakes
Check out the “Engine Dolly” in the Tech Tips.🛠
Long term........ I would get a pallet and built a “support box” to set the engine on. Then a plastic sheet, box over the top and a lot of oil in the cylinders. Some guys literally fill the crankcase with oil if storing in humid climate. If needed put casters on the pallet.
Crusing in the Passing Lane
When you get done, a 302 will fit right in there, too.
Ed
