1 members (klhansen), 90 guests, and 0 robots.
Topics128,050
Posts1,055,641
I'm trying to weld both Rocker step plate combos on my 57 truck but there is a one inch gap between it and where it is suppose to meet the rear cab corner panel. The part supplier says its the right part? Someone please help!
Got pictures?
ohwell
~Jim
I just replaced the same parts (rocker/step) on my '57 and found that the gap between the rear cab corner and step sill was significantly more than what came off (I got the Jim Carter version). I measured the old sill and it was, in fact, longer than the new one, so the gap was expected. Since this isn't a faithful resto I'm just going to fill the gap by welding in a strip of metal since there's no functional reason for the gap.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
