9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 21 New Guy | | New Guy Joined: Mar 2006 Posts: 21 | I'm trying to weld both Rocker step plate combos on my 57 truck but there is a one inch gap between it and where it is suppose to meet the rear cab corner panel. The part supplier says its the right part? Someone please help! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Got pictures?
~Jim
| | | | | Joined: Oct 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 119 | I just replaced the same parts (rocker/step) on my '57 and found that the gap between the rear cab corner and step sill was significantly more than what came off (I got the Jim Carter version). I measured the old sill and it was, in fact, longer than the new one, so the gap was expected. Since this isn't a faithful resto I'm just going to fill the gap by welding in a strip of metal since there's no functional reason for the gap. | | |
