6 members (dunfire, Bill Hanlon, stlcardinalsguy, Otto Skorzeny, papas52, Wayne67vert), 121 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Hi Y’all, While replacing the bearings on my ‘52 3600 I know the snap ring was there. Yet didn’t know what you use to remove it. I’ve tried to remove it with various needle nose plyers. Yet they all failed me. What are y’all using?????
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Riding in the Passing Lane
What bearings are you referring to. You probably need snap ring pliers.
1972 Chevy c10 Cheyenne Super
Get some snap ring pliers that will seat up to the flat spots. I had to shape them with a file. More than likely your going to ruin it getting it off so best off if you find a new one for reassemble.
Man that one is a bugger!
Don
Can’t begin to tell you how much I hate the name Stovebolt.
If you haven't done so, you have to move the bearing a little bit a way from the snap ring.
1951 1 Ton Completed
Gracious Fellows, The "Snap Ring" that I reference doesn't use "Snap Ring Pliers. It's got two 1/8" studs sticking up that I'm supposed to bring together some how. These Studs are part of a snap ring that looks big enough to be dangerous.
I'm working on the rear axle wheel bearings. Inner and Outer
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
I like the idea of pushing the bearing away from the bearing. Thanks Truckernix
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
OK I realize what we are working on now. The outer wheel brgs. on 3/4 & 1 ton rear wheels. Yes those are some stout rings. Like Nix says, push the race away from it a little. A good long pair of pliers should be able to handle it.
George
Thanks Wrenchbender
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Okay. I thought you were on the pinion bearing. For the wheel even when you have the two prongs together you still need to pry it out. I used long thin vise grips.
Don
