0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 32 | I would like to keep the stock axle under the front of my GMC 300. I am going to install a newer axle in the rear so that I can go a little faster than 45. I was just wondering if installing a brake booster is enough to slow this old truck down safely. Ive just heard that they dont stop very well stock and if I am going to be going 10 or 15 mph faster Id like to know if a brake booster is enough. I have never driven the truck as of yet because its been sitting for 50 years and I am getting it prepped and running. So i have no experience as to how well they stop or dont stop. Thanks in advance!
Logan 2010 Silverado 2500HD 1947 GMC 300
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The booster has nothing to do with better stopping. Just "easier" pedal push. It was introduced for the ladies.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Unless you're planning on running at full gross weight all the time (actually using it as a truck, not a Cowboy Cadillac) I think you'll be surprised at how effective the original brakes are. That's assuming you rebuild them to factory-original condition, not do a half-donkey job of it. Once they're back to good original condition, then you can decide if you need more stopping power. A vacuum booster simply makes your leg stronger- - - -it doesn't actually increase the effectiveness of the brake system or improve the traction of the tires. You'll just be able to lock up the wheels quicker with boosted brakes unless you also figure out a way to make the tires stick to the road better. A good set of radial tires might be one thing to consider before you spend a lot of time, money, and effort on a brake upgrade. Jerry
| | | | | Joined: Jun 2018 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 32 | Alright, sounds good thank you for the info
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Do you have 5/10 on 7.25" wheel bolt pattern? If so, '90's 3500 HD among others have D70 and 80 with that pattern, with higher ratios.
Ed
| | | | | Joined: Jun 2018 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 32 | Im not sure of the bolt pattern i have. I think i have the motor style wheels? I think that what people have called them. If I cant find an axle that will match up Ive got a machine shop down the road that said they could make adapters for me.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | How many bolts are in the front and rear? Can you post a picture?
Ed
| | | | | Joined: Jun 2018 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 32 | Its 5 bolt front and rear. I have been trying to figure out how to post pictures but havent quite figured it out yet.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Are you trying to post photos from your phone or a real computer?
| | | | | Joined: Feb 2016 Posts: 1,988 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,988 | Just yesterday I loaded 90 bales of hay on my 1957 5700, truck originally had hydro-vac booster but I have bypassed it for the time being, so with manual drum brakes on all four corners and estimated total weight of 12000 -15000 lbs. I had no problems with braking.
