0 members (),
130
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,186 Posts1,057,307 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 182 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 182 | A little help please. I have hung both doors on my restoration. And have made adjustments to the hinges at the door connection and the cab connection. The doors fit pretty good at the top and both sides. Not perfect but pretty close. Was feeling pretty good about my installation. Then I closed and latched both doors (got a story on my latches for later) for a final inspection. Anyway I look around the doors one last time to admire my work. That's when I looked at the bottom of the door from the inside where it meets the cab. And I see a gap! The gap varies from zero at the front to maybe 1/2" at the back. But only at the bottom. Guess I'm not as good as I thought. Since I adjusted the door gap pretty close and the beltline is good I'm at a loss to figure out what to do to close the gap at the bottom of the door. Looking for any suggestions and help. Thanks | | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | How is the fit where the door edge meets the cab at the front and the rear at the bottom? Do you have the lower windlace in place yet? It is the one which is attached to the floor where it meets the rocker panel. It is made of rubber and is held in place by a metal retainer. I is supposed to seal this kind of gap.
| | | | | Joined: Jun 2016 Posts: 182 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 182 | Fit is close but not perfect. Forgot about the lower windlace. Thanks for the reminder 52Carl. Thought I had a real problem. | | |
