Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Otto Skorzeny, 55shaker, 2 invisible), 117 guests, and 2 robots.
Topics128,292
Posts1,058,598
Members48,492
A little help please. I have hung both doors on my restoration. And have made adjustments to the hinges at the door connection and the cab connection. The doors fit pretty good at the top and both sides. Not perfect but pretty close. Was feeling pretty good about my installation. Then I closed and latched both doors (got a story on my latches for later) for a final inspection. Anyway I look around the doors one last time to admire my work. That's when I looked at the bottom of the door from the inside where it meets the cab. And I see a gap! The gap varies from zero at the front to maybe 1/2" at the back. But only at the bottom. Guess I'm not as good as I thought. Since I adjusted the door gap pretty close and the beltline is good I'm at a loss to figure out what to do to close the gap at the bottom of the door. Looking for any suggestions and help. Thanks
How is the fit where the door edge meets the cab at the front and the rear at the bottom? Do you have the lower windlace in place yet? It is the one which is attached to the floor where it meets the rocker panel. It is made of rubber and is held in place by a metal retainer. I is supposed to seal this kind of gap.
Fit is close but not perfect. Forgot about the lower windlace. Thanks for the reminder 52Carl. Thought I had a real problem.
