0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Hi, I did a search and was looking for some info on gas pedal linkage. I would like to use the original pedal if I can has anybody done this if so can you post a picture or info on what you used or made up to work. Thanks Steve
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | I too am interested in this for my ‘62 C-10 350 Swap. Show Steve and I what you’ve done.
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Several aftermarket suppliers sell a V-8 throttle linkage assembly for TF trucks. It should be adaptable to your series truck with some tweeking.
Martin, The aftermarket catalogues I have only show the pedal and linkage rods for 60's trucks, not the assembly.
Fred
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Does your original gas pedal have a ball and socket affair were the original linkage attaches? '53-'57 gas pedals will work with the Task Force linkage.
| | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Yes it does have a ball and socket. I will look into TF linkage. Thanks | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I'm running an aftermarket pedal setup that uses an OEM throttle cable for a 72 Camaro w/a 350 (21"). The pedal was installed by a previous owner so I'm unsure from whence it came or who made it but it works pretty good. I fit the cable after some trial and error. A 19" or 20" would fit better btw. The pic isn't that good but should give you an idea. I can provide a better pic if needed. Pic | | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thanks for the photo Volfandt I ordered the V8 throttle linkage I can make that work. Thanks again for all the info. | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Be prepared to do some modification of the linkage bracket of the Task Force linkage. It is made to fit the flat Task Force firewall, not the irregular contoured firewall of your '53. I believe that I just used stacks of washers and maybe bent one leg of the bracket on my '49. Carl
| | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Yes I thought I would have to make it fit my firewall. some how. Should not be a problem thanks Carl! | | |
