2 members (Hotrod Lincoln, 1955 1 Series), 231 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#1274371 07/30/2018 5:36 PM
I changed my differential a while back and I noticed I have a right rear wheel leak from the hub. I put on new gaskets when I did the pumpkin swap and hub bolts are tight. Someone said something about a bearing leaking. Could someone advise first things to check. Thank you.
1958 Chevy Grumman Olson step van
Moderator, Electrical Bay
Did you also change the axle bearing seals? These will leak when they're old and worn.
~ Jon
I did not. I will check that. Thanks Jon.
Crusing in the Passing Lane
Full float or semi-float axle?
Ed
Full float.
