2 members (Hush, delky), 141 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Hello All,
I just got back my truck from the body shop and getting the engine back up to snuff. I noticed that the Throttle Rod (Rod that connects from Pivot Point to Carb) is missing the little linkage that would connect to the throttle return spring (see attached pic).
DOes anyone know where I might be able to find a replacement throttle rod that I can swap out?
I have the spring clip that connects at the bottom of the motor I just don't have the little clip on the rod.
Best,
James
James,
If you do not here from anyone, check with NAPA, Saveon, Auto Zone, most all parts stores have these small items. Take the rod with you and ask the counter person for help.
Harold
Harold
...this part...?
Try parts wanted forum or make it yourself, not much to it
If you have the correct length rod already, I recommend that you fabricate that little tab and have it welded on to your correct rod. There were some changes over the years on the length of those parts.
