5 members (Hotrod Lincoln, Gray_Ghost, 78buckshot, Pete O, 1 invisible), 309 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
Hi, I did a search and was looking for some info on gas pedal linkage. I would like to use the original pedal if I can has anybody done this if so can you post a picture or info on what you used or made up to work. Thanks Steve
I too am interested in this for my ‘62 C-10 350 Swap. Show Steve and I what you’ve done.
Several aftermarket suppliers sell a V-8 throttle linkage assembly for TF trucks. It should be adaptable to your series truck with some tweeking.
Martin,
The aftermarket catalogues I have only show the pedal and linkage rods for 60's trucks, not the assembly.
Fred
Does your original gas pedal have a ball and socket affair were the original linkage attaches? '53-'57 gas pedals will work with the Task Force linkage.
Yes it does have a ball and socket. I will look into TF linkage. Thanks
V
V Offline
I'm running an aftermarket pedal setup that uses an OEM throttle cable for a 72 Camaro w/a 350 (21"). The pedal was installed by a previous owner so I'm unsure from whence it came or who made it but it works pretty good. I fit the cable after some trial and error. A 19" or 20" would fit better btw.
The pic isn't that good but should give you an idea. I can provide a better pic if needed.
Pic
Thanks for the photo Volfandt I ordered the V8 throttle linkage I can make that work. Thanks again for all the info.
Be prepared to do some modification of the linkage bracket of the Task Force linkage. It is made to fit the flat Task Force firewall, not the irregular contoured firewall of your '53. I believe that I just used stacks of washers and maybe bent one leg of the bracket on my '49.
Carl
Yes I thought I would have to make it fit my firewall. some how. Should not be a problem thanks Carl!
