| | | Forums66 Topics128,193 Posts1,057,244 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | I started noticing the outer edge of my front drivers side tire starting to wear smooth earlier this Spring, and in the last week or so, I'm starting to get (occasionally) what feels like wandering or a pull to the right. Before I dig in and get it up on the stands, I'm curious as to where would be the first place(s) to check. Tie rod ends? King pin? It hasn't been bad and it doesn't pull fast and hard, just sort of a wandering as if I crossed over the crown of the road. And as soon as I pull it back, it's gone again. Any ideas or suggestions on where to start, or where not to bother looking? BTW, the other tires have all held up great and show no sign of uneven wear, even after 24k on them. Thanks for any help on this. Butch
"When I rest, I rust" 1951 3100 5 window w/ '56 235
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy showme, Did you ever have the truck aligned? Have you checked your tire pressures? Look for anything loose in the front suspension and in the steering box adjustment. Hope that helps. | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Tread wear to the outside of the tire center is usually caused by excessive positive camber (top of the tire tipped outward). That can be caused by worn king pins and/or king pin bushings. Stand back from the front of the vehicle a few feet and eyeball the tires. If my guess is correct, you should be able to see a slight tipping of the tire out at the top. Jack up one side of the front at a time, grab the tire top and bottom, and try to rock it back and forth. If it moves, check the wheel bearings and the king pins and bushings for looseness. Changing camber involves bending the axle, so be sure all the possible loose spots are covered before looking for someone to do that. A few heavy duty truck alignment shops still bend axles, but some of them won't work on small trucks. Jerry
| | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | Never had an alignment done on it in the 5 years I've had it. The tires had 1,000 miles when I bought it, and I've never had any problem with drifting or pulling until now. I should have had it done this spring when I started noticing the wear, but I was waiting for the cold and rain to break into spring weather so I could get under it and check the front end and do spring maintenance on it, then it turned hot and humid here in Missouri overnight, and I've been putting it off till now. It's my daily driver. If I'm not on my bike, I'm in it. Drive it 75 miles to St. Louis every week or two, and I usually let the wheel go for a bit to check it's tracking. Up till the last week or so, it's been fine. I keep a close check on tire pressure and that's ok too. The steering box was going to be next on the list to check out. This truck has always had very easy steering (unless I'm backing out of a tight spot, of course.) HL, I will check that. As much as I would rather redo the tie rods, I've been thinking the king pin is the culprit, so I will follow your lead on that. I knew the camber on these were set in the factory, so I don't even want to think about how I'd get that fixed. There are a few good trucking companies, and truck service guys around here though. Are there any parts houses that are, how should I say this, selling good grade parts for the front end? Being from Missouri, I usually go with classic parts, jim clark or lmc, but I've found that although most of their stuff is good/ok, I don't want to put junk parts in critical (and hard to get to) places. Thanks, you guys, I'll keep you posted as soon as I can get under it.
| | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | You can contact Sid at droppedaxle.com. He put my king pins in mine when he bent my axle. Just a thought.
Chris | | | | | Joined: Mar 2014 Posts: 4,510 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,510 | Check Rock Auto before you buy anything. They have plenty of parts for these.
https://www.rockauto.com/en/catalog/chevrolet,1951,truck,3.8l+235cid+l6,1487279,steering,king+pin+set,7340
Moog and AC Delco are both fine. I don't know anything about the other maker they show.
Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
