Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (68ironhead, JW51, 1 invisible), 574 guests, and 2 robots.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
#1274131 07/28/2018 3:38 PM
My oil pressure guage reads less than half (15#), how can I determine if oil pump needs rebuild or guage is wrong?
What are you working on? You’ve got to help us help you!
52 chevy pick up with original 216 bored to 235 to put in insert brgs
What do you expect your oil pressure to be? I’ve seen 235s running just fine at 15#.
A 216 with 15 pounds of oil pressure is just about normal. At hot idle most of them barely move the needle at all. A possible fix would be to use a high volume oil pump, but those don't exist for the 216/235 engines. I'm working on a modification to install small block V8 pump gears in a 216 housing, but I don't have a working prototype finished yet. That would increase the pump output volume by about 20% and also raise the pressure a little. If you adjust the main bearing clearance down to .0015" or so, the pressure will rise a little. Adjusting the rods doesn't help because they're not pressure-lubricated.
Bob R #1274188 07/28/2018 11:40 PM
thanks!
Bob R #1274191 07/28/2018 11:50 PM
Gathering information from your other post regarding overly tight connecting rod bearings on a recent rebuild (216 bored out to 235), I would suspect that your machinist either is unfamiliar with these engines because he is too young, or he is old enough to be familiar with them, but too old to see what he is doing anymore.
He didn't get the connecting rod clearance right, or he didn't check for bent connecting rods, or bent them while tightening the wrist pin bolts, which will cause the appearance of them not having enough clearance.
If he did not know how to do those tasks properly, then it would stand to reason that he was not familiar with the main bearing shimming procedure. That would cause low oil pressure if too many shims were used.
My apologies for abruptness, if said machinist was you. smile
Carl
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.124s Queries: 14 (0.120s) Memory: 0.6166 MB (Peak: 0.6711 MB) Data Comp: Zlib Server Time: 2025-09-22 14:27:13 UTC
Valid HTML 5 and Valid CSS
