4 members (walter74, Greg_H, Guitplayer, RLB), 94 guests, and 2 robots.
Topics128,055
Posts1,055,785
#1273790 07/25/2018 8:50 PM
So,, I got a s10 front end I'm putting under my 49 3100 . It's out of like a 2004 it has bigger brake lines than the rest of my build. Everything from M.C. back is 3/16 O.D. tubing
the rear axle is out of a 4wd s10. It has disc brakes. the front lines are 1/4 inch O.D. they also are disc . Does the front need more capacity or what? thanks for the wisdom!
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
Short answer is yes.🛠
