| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Do you need brake shoes(drum brakes) or brake pads(disc brakes)? Most auto parts should be able to order new lined shoes, if that is what you need, on an exchange basis. Best to verify if it is really a 6000? Series or whatever before searching for parts.
The 'heat flap' is designed for warming up and keeping carb. ice from forming, if you get a service manual for eBay or such, it should show pictures.
Ed
