1 members (baldeagle),
80
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | I am using bedsides from a '67 stepside to replace the bedsides on a '54 3100. I need to fill all the holes where the '67 fenders bolted up. Is there a vendor that offers weld in plugs for this or do I have to hand cut the plugs from scrap panels that I have? | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Get a piece of copper for a back up (atleast 1/4" thick). Fill the holes with weld. The weld won't stick to the copper and the backside will be perfectly flat. Grind the face of the weld flat. It's easier than you think. You can fill holes up to 1/2" dia. | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | you dont need a piece of copper 1/4 thick, a common copper pipe smashed flat will do just fine | | |
