1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Which was considered "better" the gmc model or chevrolet?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | First thing to get straight : truck-series names: Chevrolet Advance-Design trucks GMC New Design trucks Mid/early-year 1947 through mid/early-year 1955
Chevrolet sold 1/2 ton through 2 ton trucks GMC sold trucks from 1/2 ton though much larger than 2-ton trucks
In 1955, the series names changed to: Chevrolet Task Force trucks GMC Blue Chip trucks
The main mechanical differences were in the engines/radiators, and in the grills (and, in the wheels). Chevrolet 216/235/261 GMC 228/248/302 (in small trucks) In 1954, there were significantly different interior dash board and gauges.
GMC engines were considered to be better, for several reasons: - better/harder casting metal - better carburetors - other ?? | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Thanks for the soda by side comparison TC..... that is very helpful.
Was one more expensive than the other and thus considered "premium"?
Also, would a gmc be considered as more desirable in the restoration world?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | " Was one more expensive than the other and thus considered "premium"? " GMC was probably more expensive. GMC was probably thought of as "more premium"
" Also, would a gmc be considered as more desirable in the restoration world? " Hmmmm ..... I am not going to touch that one. | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Ha!...... probably a smart move. We might crash the website.
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Just some background, my buddy just bought an identical suburban to mine except his is a gmc. Just trying to get my info straight so I dont sound like an idiot in casual conversation.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I recently was up at a place picking up some parts on a craigslist, this guy sells lots of 47-55 stuff. A guy was just buying a seat for a pickup and I helped carry out the bottom section. Noticed it had twice as many springs in it as my 53 Chev 3100. He said it was a GMC seat thats why. Apparently the same exterior dimension but the insides are built better.
I just saw a movie documentary on the Korean conflict and there were many CCKW duece and a 1/2s. Showed them travelling down snow ridden trails in minus temperatures. They hadn't made that model since the end of WWII but there it was still working hard for our freedom. Give your buddy and his GMC all the respect it deserves IMHO.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | True.....
I'm looking forward to pulling into car shows as a suburban school bus fleet! Should be an interesting sight to see!
| | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | Also might add that batteries are connected differently; gmc is positive ground, Chevy is negative ground. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, good info, papas52
Which type of ground is better, and why? (this should be interesting) | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Negative ground obviously because that's the way it's supposed to be
| | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | Well, remember YOU started this; haha. For a magnet, the field leaves the negative side, travels through the air and enters the positive side of the magnet to form a magnetic field. GMC thought following this naturally occurring feat would work better in a battery circuit to give a hotter and more reliable starting corcuit, thus the positive ground for the return.
| | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | Negative ground became the norm in most vehicles in the fifties with the introduction of the transistor which requires a specific current flow direction. I believe that to be somewhere around 1955. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is why British Lucas auto electronics have such a good reputation? | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Ha! Yes I fought Lucas stuff on an old triumph motorcycle I had when I was 16. Lucas wiring is .......challenging.
| | | | | Joined: Aug 2001 Posts: 3,601 Moderator | | Moderator Joined: Aug 2001 Posts: 3,601 | Lucas made a lot of stuff! The only thing that didn't suck, was their Vacuum cleaners.  Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Did those "Lucas" vehicles get their grounds through the frame, or did they have negative hot wires and positive ground wires? | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | GMC frames were heavier gauge steel than Chevy frames. | | | | | Joined: Mar 2015 Posts: 13 New Guy | | New Guy Joined: Mar 2015 Posts: 13 | I will give my two cents on this thread since I'm a GMC guy. I think a lot of good statements were mentioned above. I feel from just talking to people at shows and what not that GMC's are actually less desirable as a restoration project. The reason is simply it's easier to find parts for the Chevy trucks than the GMC trucks. However, owning several GMC's myself, you learn to know and meet people and where to find parts. I prefer GMC's because there are just fewer of them. You go to truck shows and you see Chevy AD trucks everywhere, but you have to look somewhat hard to find a GMC , and when you do, you have to go look at it. I think both makes of this style of truck were good trucks in their day and probably the most popular truck today that GM ever made. I do feel the GMC's were built "stronger", but they were also tailored to the farms and ranches and more so as an every day working truck where as Chevy marketed their truck for the more suburban type customer. Today, I don't really think that matters at all just due to how we are using these trucks(as show vehicles). It really comes down to personal preference and what kind of deal you get when purchasing. Some people like the looks of the Chevy grilles better where others like the looks of a GMC grille better. Anyway you look at it, it's great to see both makes at these truck at shows and on the road! Keep building them!!!!! | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | The BIG other feature on engines...........The GMC engines were insert bearing with full pressure lubrication. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Nice post, Skeet
Supposedly GMC 6 cylinder engines last longer than Chevrolet 6 engines, because the GMCs are harder due to a higher nickel content?
Yes the GMC grills were "bulkier", and the 54/55 Z-series grill was a monster/monstrosity. I admire that ugly grill on my Z-series GMC COE.
The GMC carburetors were/are far superior to Chevrolet Rochesters
Regarding lubrication, yes, GMC engines had high-pressure engines before Chevrolet changed in 1954. However, the 1958 Chevrolet 261 had a full-flow oil filtration system before GMCs. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | I know we're talking about 47-55 trucks, but I think if you go back to the 30s GMC used engines from some of GM's car divisions, such as Pontiac L-head sixes. Maybe others. Do we have any 30s GMCs in the Gallery? I will research that.  I guess oldgmctrucks.com would have info like that. (I used to frequent that forum, but frankly, it's not particularly user friendly.)
Professional Novice
| | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | I'll never forget what I heard was the difference between GMC, and Chevy from when I was a little kid. A GMC was just a Chevy with lock washers! | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 |
Canadian light duty GMCs had Chevy engines. | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | I'll never forget what I heard was the difference between GMC, and Chevy from when I was a little kid. A GMC was just a Chevy with lock washers! I did notice star lock washers on the inner fender-to-fender bolts on a pristine GMC 3600. Chevrolet's don't have them.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Having disassembled many of both, I've found Chevy had rivets, in a lot of places, whereas the GMC's had bolts. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GMC's took over some Buick 6 cyl. engines when Buick went to 8's.
Ed
